• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    DWG TrueView
    Member
    jameswroberts81
    Trueview closing out when I click plot (winXP)
    569 Views, 6 Replies
    01-12-2011 04:56 AM
    I am trying to plot from trueview and when I click plot the program closes.  I dont get my normal screen with the options to choose my plotter/printer.
    This only happens to .dwg files.
    This is on windows XP and it is trueview 2011.
    If you all can provide a solution it would be greatly appreciated.
    James
    Please use plain text.
    Product Support
    Re: Trueview closing out when I click plot (winXP)
    01-13-2011 11:06 AM in reply to: jameswroberts81
    Do you get any type of error message? If so, please post a screen shot of it. Regardless, the first thing to try is likely an Uninstall / Reinstall. If the problem still persists, load TV on another machine in your offiec and try to plot. If that machine also crashes, then likely there is something in your companies environment that is causing the problem.
    Shawn Niles
    Product Support Team Lead
    Product Support
    Member
    jameswroberts81
    01-13-2011 11:09 AM in reply to: Shawn_Niles
    I should have mentioned in my first post that I did do a complete uninstall of the softare and reinstalled it.  There is no error message at all it just closes the window as if I were to click on close.
    It is happening to one particualar PC. We have no trouble printing from other PCs.
    Thank you
    James
    Product Support
    01-19-2011 06:46 AM in reply to: jameswroberts81
    How are you attempting to plot? Are you just clicking on the plot button? If so, can you try to plot from the pulldown when you click on the Big D? It would be useful to know if you can plot using a different method.
    Shawn Niles
    Product Support
    New Member
    baik
    01-24-2011 11:45 PM in reply to: jameswroberts81
    i read this discussion and i have same problem about printing from Trueview 2011. After clicking to the button "PLOT" program closes. From others PC working properly. When I unwrap the menu TV (Big "D"), then I choose PLOT and becomes the same. As wrote collegue, progrma closes without erros or some windows with message. We using OS WinXP(x86).
    Thank you in advance
    Peter
    New Member
    11-18-2011 04:36 AM in reply to: baik
    Same Problem Here,   sometimes it works, sometimes in shuts down without error messege.
    Any Information appreciated.
    New Member
    Alfa_Suraj
    11-20-2011 08:42 PM in reply to: jameswroberts81
    Simmilar problem here,
    Machine gets hannged completely when clicked on "Plot" or "Open", and thus needs to kill the application through taskmanager.
    I already posted my compliaint, but no response in that window.
    Please provide solution ASAP as users are suffering for last 1 week.
