I need to open a dwg and just downloaded Trueview. It crashes with a Out of System Memory message at 81% and never opens the document. The dwg file is 190 M. I looked up the problem here and see the solution of clearing the Autodesk cache. I did that, but it did not help.
I have a 32-bit system (Win7) with 4G ram, which is the max. Does that mean I have to go to a 64-bit sytem?
Thanks, Joel
Solved by Joel3DM. Go to Solution.
Yes, I took care of the problem. I went 64-bit and doubled my ram with a new computer. It works fine now!
