I'm new to Trueview & just had Trueview 2014 installed and am using the DWG to PDF.pc3 in a Page Setup to Batch Plot plot files.
Files are Civil 3d 2014.dwg files.
Using the following setting in Trueview > Batch Plot > Publish Options > General DWF/PDF options > Type > Multi-sheet File
When multiple sheets are Published via Trueview Batch Plot, even though Multi-sheet-file is selected the PDF's are all individual files and not combined in a single pdf as expected.
Is there possibly another setting to specify the multi-sheet-file I may be overlooking or has anyone else had this issue when batch plotting?
If I use SSM in Civil 3d and plot multiple sheets to pdf, via dwg to pdf, it's one combined pdf.
Dean,
In options of DTV2014 I have the Printer Support Path locations pointed to our network printer support file folders.
\Config\, \Description\ & \Plolt Style\.
DTV2014 appears to be using the Page Setups which live in each individual sheet plotted AFAIK.
pendean wrote:
or the default on that DTV pop-up?
Are you referring to the Publish dialog within DTV2014?
I can't seem to find a way to plot to pdf other than as single pdf files no matter what I try for settings from the Publish dialog.
Has to be a setting on my end because I've talked to others outside our organization who are able to create multi sheet pdfs in DTV2014.
