• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    DWG TrueView
    New Member
    Trueview 2013 on Terminal Server
    2553 Views, 7 Replies
    06-12-2012 09:15 AM
    Installed Trueview 2013 on Server 2003 32-bit server and have some weird issues that occured with the 2012 install.
    1. The first issue is when users first run Trueview an installation dialog box pops up.  Unless they are local admins, it will then just disappear.  With 2012 I was able to make them local admins, have them start the application, then would be able to take the rights away.  It doesn't seem to be the case for 2013.  I do recall changing some folder rights (and maybe registry permissions) to allow them to run the app without admin rights, but can't remember what those changes were.
    2. The other issue is I've noticed that if you look at the options on Trueview (File->Options) and look at the file paths for the settings, they are not always pointing to the user you are signed in as.  (e.g. C:\Documents and Settings\sysadmin\application data\autodesk\dwg trueview 2013\r10\enu\support) Trying to change to the current user will work, but I don't want to have to do that for each user.
    Please use plain text.
    New Member
    Re: Trueview 2013 on Terminal Server
    09-07-2012 01:45 AM in reply to: benhar77
    I've always problem with DWG Trueview. Without local admin rights, application doesn't start.
    Is it possible to use this application on Terminal Servers ?
    Member
    10-24-2012 06:55 AM in reply to: benhar77
    Hey I was just wondering if you have had any luck with this, I have been asked to get True view and inventor viewer working on our terminal server but there is no way I want users to have admin rights on the server.
    Carl
    *Expert Elite*
    pendean
    10-24-2012 07:28 AM in reply to: carlc
    Try posting in the Installation forum:
    http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    *Expert Elite*
    TravisNave
    10-30-2012 09:19 AM in reply to: benhar77
    Trueview, nor any other Autodesk product is supported on Terminal Services.  Though Trueview is not necessarily licensed on lease, per say, the usage of the product per a network server is prohibited by the EULA.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Distinguished Mentor
    ampster
    10-30-2012 10:23 AM in reply to: TravisNave
    I don't recall which softwares, but there are a couple that have been certified and allowed to run on citrix servers IRC.  Maybe Revit and one other..
    *Expert Elite*
    TravisNave
    10-30-2012 10:47 AM in reply to: ampster
    Yes, Citrix with special network licensing is approved for some of the product line. But Terminal Services is not supported for any of the products.
    Travis Nave
    New Member
    01-05-2013 02:45 AM in reply to: TravisNave
    We used to run DesignView 2011 on our Terminal Machine with no problem but now users cannot run 2013 without getting the "preparing to install" message.  That said, Administrators are able to open the program without any problem.
    Is there any sort of work-around to allow users to use the program without giving them Administrator privileges on our network?
    Thanks! - David
