DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Trueview 2011 - ribbon not showing when opening dwg
8 REPLIES 8
Message 1 of 9
Solway
5415 Views, 8 Replies
Hi i have just installed Trueview2011 from 2010. Did a complete uninstall, then drive/register cleaner before installing 2011.
However when i open drawings the ribbon bar (or any tool bar) does not load at startup, i have to manually go into the menu and select "show ribbon, command bar etc.." plus it does not save the UI layout when i close and open trueview again.
i have tried repair, uninstall etc.. with all drive/folders cleaned and registy cleaned. without success.
i do on the other hand, have full version of Autocad 2010 installed on same machine. ditto design review 2010.
Any help please?
Regards
Andrew
8 REPLIES 8
Message 2 of 9
Solway
in reply to: Solway
anyone? please help
Message 3 of 9
Silvia.Menon
in reply to: Solway
I tried but could not reproduce this behaviour...
DWG TrueView saves these settings in the registry, maybe there is a permission issue...
What operating system are you running?
If it is Vista or Windows 7 - is the problem the same when you start DWG TrueView via right-click > Run as Administrator?
Regards
Silvia
Silvia Menon
Autodesk Product Support
Autodesk, Inc.
Message 4 of 9
Solway
in reply to: Solway
hi thanks for the reply
trueview2011 is set to default app on dwgs
it works ok if you open the program first, then go file open dwg
however if just double clicking on dwg file to open (without the trueview open) the ribbon won't show.
im on vista 32bit
i have kaspersky internet security 2011 (had tried installing with this disbaled)
Autocad 2010 is install
Message 5 of 9
Silvia.Menon
in reply to: Solway
thanks for the detailed description. I can reproduce this now and will report it to our development team.
Best Regards
Silvia
Silvia Menon
Autodesk, Inc.
Message 6 of 9
Solway
in reply to: Solway
any news on a hotfix for this???
Message 7 of 9
youngdave9976
in reply to: Solway
I have the same issue, is there not a fix yet. When I first rn the product after install the ribbon worked and I really liked the interface. After shutting down and re-opening the ribbon had dissapeared. It's a shame as the product is nice.
Message 8 of 9
aaron_chia
in reply to: Solway
Hi, I have the same problem on Truewiew 2011 - ribbon not showing at all.
Is there a solution for this?
Aaron Chia
Message 9 of 9
Silvia.Menon
in reply to: aaron_chia
Hi all,
this has been addressed in DWG Trueview 2012. You can download it from here:
http://www.autodesk.com/trueview
Best regards
Silvia
Silvia Menon
Support Specialist
Product Support
Autodesk, Inc.
http://www.autodesk.com/autocad-support
