DWG TrueView
Member
Message 1 of 5 (7,074 Views)
TrueView transparent layer stippling
7074 Views, 4 Replies
12-31-2012 07:27 AM
I loaded trueview 2012 and 2013, 32 and 64 bit on several computers. On some computers, transparent layer objects (like walls) display stippled, instead of a smooth homogeneous color.
Is there a way I can fix this?
I searched on the subject for a couple hours and could not find an answer.
Thanks!
pendean
Message 2 of 5 (7,069 Views)
Re: TrueView transparent layer stippling
12-31-2012 11:58 AM in reply to: opsjjf
What is different about the display settings, video cards, and video abilities of the computers that can't display properly?
Are you testing the same exact single file to rule out file settings variations?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Member
Message 3 of 5 (7,054 Views)
01-02-2013 02:31 AM in reply to: pendean
Thank you for your response.
For this reply, I am using the exact same file.
The first attachment, "screen print from autocad 2011 bp ll.png", is a screen print from a remote session,screen resolution 1364x768, I asked for a 24 bt true color resolution. Windows 7 64.
The second attachment, "nv57h94u.png",is a screen print from Gateway nv57h94u, screen resolution 1366x768, 32 bit true color. This is the same system used to remote into the system above. Windows 7 64.
The third attachment "bp ll screen print compaq.png", is a screen print from a CompaQ Presario amd based 64 bit os, screen resolution 1920x1080, 32 bit true color. Windows 7 64.
I also have 2  I5 760's with an Nvidia GeForce 210 running 32 bit XP, one  that shows no stippling using Trueview 2012 and one that does. I can get the screen resoutions if you want them.
pendean
Message 4 of 5 (7,044 Views)
01-02-2013 05:20 AM in reply to: opsjjf
There is no setting inTrueview to change anything in the display: it's all about the syetm graphics card (and it's ability/updated drivers) and Windows Display settings. Dig deeper into the systems that work vs. the ones that do not.
Member
Message 5 of 5 (7,015 Views)
01-05-2013 06:00 AM in reply to: pendean
Thank you for your help.
I found an answer
Actually, there is a setting in TrueView that controls transparency quality under Manual Performance tuning, which I set to High (Slower).
Best Regards!
Joe
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
