DWG TrueView
CV438
Message 1 of 5 (1,065 Views)
TrueView 2013 error displaying an ACA2012 XREF
1065 Views, 4 Replies
05-24-2012 12:00 PM
Using Trueview on one machine to open, view and print drawings created in ACA2012.  The actual "model" file opens and displays walls correctly.  But if the "model" file is XREF'ed into a "Sheet" file.. the walls don't display correctly in TV2013...
Any ideas?  Downgrade to Trueview 2012?
pendean
Message 2 of 5 (1,059 Views)
Re: TrueView 2013 error displaying an ACA2012 XREF
05-25-2012 06:16 AM in reply to: CV438
A limitation so far... .
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Contributor
robindeurloo
Message 3 of 5 (1,003 Views)
07-06-2012 06:41 AM in reply to: CV438
Any solution for this problem yet? I seem to have the same issue.
Valued Contributor
genem
Message 4 of 5 (805 Views)
01-24-2013 10:58 AM in reply to: CV438
Same deal here. This is bascially a stripped-down AutoCAD. You would think things would display the same.
Also, I do not see any object enabler for Architecture/MEP items.
genem@... (NNTP handle: genemarz)
You may recognize me from the
hundreds of previous newsreader posts
I've made over the last 10 years
as genemarz
pendean
Message 5 of 5 (795 Views)
01-25-2013 05:28 AM in reply to: genem
Plain AutoCAD 2013, not ACA, has a limitation with ACA objects being Xrefed: DTV is the same way. Autodesk hasn't fixed the core program yet so it's fair to say DTV is also broken too.
No fix yet folks, for either program. Sit tight and wait or start pestering Autodesk staff here to gain access to DTV2012 versions instead.
You are not logged in.
Ask the Community
