• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    DWG TrueView
    Active Contributor
    TrueView 2013 deployment
    11298 Views, 12 Replies
    03-28-2012 12:04 PM
    I have downloaded the newest package with Design Review and TrueView 2013.  I am trying to automate the deployment via batch for SCCM packaging for 1400+ computers in 26 offices.  With all previous versions of the apps I have been able to run the dwgviewr.msi files, but for some reason TrueView will not allow it to be installed via the msi and only when running Setup.exe.  Am I missing something with this version?
    Mark LaBell, Jr.
    BIM/CAD Technical Specialist
    SSOE Group
    www.linkedin.com/in/marklabelljr
    Please use plain text.
    Valued Mentor
    Re: TrueView 2013 deployment
    03-28-2012 10:02 PM in reply to: mlabell
    what is the url for the combined desgn review and trueview 2013 package?
    Active Contributor
    03-29-2012 04:31 AM in reply to: mlabell
    Link to the install.
    http://usa.autodesk.com/design-review/download/
    Also if you download the TrueView only install seperately and try to deploy via the msi the same scenario happens were it requires the Setup.exe to install the application.
    Mark LaBell, Jr.
    SSOE Group
    Valued Contributor
    03-29-2012 04:38 AM in reply to: mlabell
    I'm seeing this as well.
    I automatically deployed the MSI file, thinking it would work like the 2012 version and told the GPO to uninstall the previous version first. But when it goes to install the new version, it fails.
    Now I'm stuffed? :smileyfrustrated:
    The Design Review MSI works fine.
    Active Contributor
    03-29-2012 04:44 AM in reply to: tony_72000
    Currently I am calling the ADR msi then I use the below syntax to quielty call the setup.exe for TrueView.  Not preferred (since it technically reruns ADR) but it is working in for a few installs that I need to do right away.  The other 1396 installs can hopefully wait for a better solution.
    "%~dp0setup.exe" /w /qb /i %~dp0Setup.ini
    %~dp0 = the relative path of the file.
    Mark LaBell, Jr.
    SSOE Group
    New Member
    04-17-2012 10:33 AM in reply to: mlabell
    I have made a Transform file (.MST) available here, and also on my website at http://www.barbarianhamster.com/Services/DontRunSetup.zip
    The full gory details of how it came about, and what it does, are available on my blog, http://barbarianhamster.blogspot.com
    James Keirstead
    http://www.linkedin.com/in/jameskeirstead/
    Senior Information Systems Engineer
    Perigon International, Inc.
    http://www.perigoneng.com
    http://www.linkedin.com/company/perigon-international-inc-/
    Valued Contributor
    skatterbrainz
    04-23-2012 08:49 PM in reply to: mlabell
    I've been playing around and found the following works so far pretty well...
    setup.exe /Q /W /I setup.ini
    Get the Visual LISP Developer's Bible 2011 Edition, and the AutoCAD Network Administrator's Bible 2012 Edition on Amazon Kindle
    Distinguished Contributor
    04-24-2012 03:26 AM in reply to: skatterbrainz
    As above. I've just used "%deployment dir%setup.exe" /W /QB /I
    AutoCADM 2011 SP2
    XP 32-Bit SP3
    Valued Contributor
    04-24-2012 04:19 AM in reply to: james.keirstead
    This works a treat, thanks a lot.
    Active Contributor
    04-24-2012 04:51 AM in reply to: james.keirstead
    Editing the msi did the trick! Deployment ready to roll...
    echo ***Install PreReqs***
    rem Do this first because some uninstalls fail because of a bad install of VCredist 2005
    "%~dp0support\VCRedist\2005\vcredist_x86.exe" /q:a /norestart /c:"vcredist_x86.exe /q:a /c:""msiexec /i vcredist.msi /qn /norestart /l*v %temp%\vcredist_x86.log"" "
    echo .
    "%~dp0support\VCRedist\2008\vcredist_x86.exe" /q:a /norestart /c:"vcredist_x86.exe /q /norestart"
    echo .
    "%~dp03rdParty\DirectX\DXSETUP.exe" /silent
    echo.
    echo ***Removing 2010 Products***
    echo ***Uninstalling ADR***
    MsiExec.exe /x {55D9E026-DCB0-46FF-B60A-68B972228CF6} /passive
    echo ***Uninstalling TV***
    MsiExec.exe /x {5783F2D7-8028-0409-0000-0060B0CE6BBA} /passive
    MsiExec.exe /x {5783F2D7-8028-0409-0100-0060B0CE6BBA} /passive
    echo ***Unistall 2011 Products***
    MsiExec.exe /x {8D20B4D7-3422-4099-9332-39F27E617A6F} /passive
    Msiexec.exe /x {5783F2D7-9028-0409-0000-0060B0CE6BBA} /passive
    Msiexec.exe /x {5783F2D7-9028-0409-0100-0060B0CE6BBA} /passive
    echo ***Unistall 2012 Products***
    MsiExec.exe /x {A49BDCBE-590E-43A6-AB77-7C40E499B7C1} /passive echo
    Msiexec.exe /x {5783F2D7-A028-0409-0000-0060B0CE6BBA} /passive
    Msiexec.exe /x {5783F2D7-A028-0409-0100-0060B0CE6BBA} /passive
    echo ***Unistall ADR Plug-ins***
    echo ***Uninstalling ADR DGN plugin***
    MsiExec.exe /x {8F7A766B-9E2E-4895-B4B2-958D035F09B9} /passive
    echo ***Uninstalling ADR JT plugin***
    MsiExec.exe /x {F4C0A7CD-3A4C-4275-9CF1-9CD5136E2FE2} /passive
    echo ***Install ADR 2013***
    "%~dp0x86\ADR\SetupDesignReview2013.msi" /qn /norestart DEFAULTFILETYPE=dwf ADSK_DESKTOPSHORTCUT_1=0 ADR_DONOTSHOWAGAIN=1 ADR_NEXT_INITIAL_CHECK=1 PREFERENCELOCKED=1 HIDE_RESTAB=1
    "%~dp0x86\DGN\SetupDesignReviewDGNImporter.msi" /qn /norestart
    "%~dp0x86\JT\SetupDesignReviewJTImporter.msi" /qn /norestart
    echo ***Install TV 2013 x64***
    "%~dp0support\VCRedist\2005\vcredist_x64.exe" /q:a /c:"vcredist_x64.exe /q:a /c:""msiexec /i vcredist.msi /qn /norestart /l*v %temp%\vcredist_x64.log"" "
    "%~dp0support\VCRedist\2008\vcredist_x64.exe" /q:a /c:"vcredist_x64.exe /q:a /c:""msiexec /i vcredist.msi /qn /norestart /l*v %temp%\vcredist_x64.log"" "
    "%~dp0x64\dwgviewr\dwgviewr.msi" /qn ADSK_DESKTOPSHORTCUT_1=0
    Mark LaBell, Jr.
    SSOE Group
