DWG TrueView
mho
Member
mho
Message 1 of 6 (4,024 Views)
TrueView 2011 deployment via SCCM 2007
4024 Views, 5 Replies
03-15-2011 01:11 AM
Hi.
I'm trying to install TrueView 2011 via SCCM 2007. Have any of you guys tried this?
Everytime I try to install, it fails because DirectX isn't installed. I've tried to install DirectX separately via the following command:
DXSETUP.exe /silent
When I install it from a command prompt, it works fine, but from SCCM it never installs.
Everything else seems to be working fine.
Could someone please help me with this?
mho
Member
mho
Message 2 of 6 (4,004 Views)
Re: TrueView 2011 deployment via SCCM 2007
03-16-2011 03:23 AM in reply to: mho
Well I found this command, and it works:
setup.exe /w /t /q setup.ini
Member
yannara
Message 3 of 6 (3,986 Views)
03-18-2011 07:08 AM in reply to: mho
I fought with this same dxsetup silent issue in sccm for a whole week. I'll need to try this one. Will those commands you invented, create a system reboot after install?
Member
yannara
Message 4 of 6 (3,979 Views)
03-19-2011 02:23 AM in reply to: yannara
Nope, I'm still having this error lack of Direct X during install,
Product: DWG TrueView 2011 -- Error :: Please install DirectX before installing DWG TrueView 2011.
What should I do? How Direct X could be run silently?
New Member
Tomas.Donath
Message 5 of 6 (3,893 Views)
03-30-2011 11:54 PM in reply to: mho
unfortunately not a solution but the same problem with Enteo NetInstall. Only interactive installation of DirectX seems to install it in a way, that true view setup is able to detect this properly.
Ralph
Member
yannara
Message 6 of 6 (3,861 Views)
04-02-2011 06:53 AM in reply to: Tomas.Donath
Yes, I managed to install Direct X silenty via SCCM by adding settings that user is allowed to interact. It works this way, and there is no problem.
My order for installation is:
1. Install Direct X and reboot
2. Install VCRedist 2005
3. Install VCRedist 2008 and reboot
4. Install msxml6.msi
5. Install Trueview and reboot
You are not logged in.
Ask the Community
