DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
TrueView 2009 - Save workspace settings
3 REPLIES 3
HerrSenkowski8799
1009 Views, 3 Replies
I'd like to save the workspace settings of TrueView 2009, e. g. closed ribbons, so that I get a "minimal" look and feel even after restarting TrueView 2009. The problem I have is, that TrueView always switches back to default settings and I don't find a way to keep those settings...
I would appreciate any help on that.
Michael
3 REPLIES 3
I have tried reproducing this with DWG TrueView 2011 and it works fine - when I restart DWG TrueView and open a file, the interface settings are exactly as they were when I closed it.
Do you have the problem only in the 2009 version or in the 2011 version too?
Regards
Silvia
Silvia Menon
Autodesk Product Support
Autodesk, Inc.
Petrvs
in reply to: Silvia.Menon
I have the same problem as Mechael with DWG True View 2011. Ribbon is always closed and grid is always on. I prefer to start with open ribbon and no grid (also I have no idea how to set grid to show only intersection points, not full axis) .
Thank You in advance,
Petr
Silvia.Menon
in reply to: Petrvs
just wanted to let you know - this has been addressed in DWG Trueview 2012. You can download it from here:
http://www.autodesk.com/trueview
Best regards
Silvia
Silvia Menon
Support Specialist
Product Support
Autodesk, Inc.
http://www.autodesk.com/autocad-support
