DWG TrueView
New Member
gspiper
Message 1 of 2 (1,775 Views)
True View 2014 Fails at Launch & Won't Uninstall
1775 Views, 1 Replies
08-13-2013 04:48 PM
I have spent HOURS trying to install True View 2014 on a customer PC (new Dell Optiplex 9010 all-in-one running Win7 64-bit Enterprise) with no success.  Downloaded the 64-bit installer and install proceeded normally.  When laucnhed, the first error appeared:
Researched this and found numerous references to .Net 3.5, .Net 4.0 and C++ redistributable modules.  All of these had previously been installed on this PC and were up to date with all patches.
When I attempt to uninstall TrueView 2014, Application hangs on an "initializing" screen.
This is the buggiest installer I have worked with in years.
Anyone have a solution that will actually works ?
Glenn
pendean
Message 2 of 2 (1,760 Views)
Re: True View 2014 Fails at Launch & Won't Uninstall
08-14-2013 05:27 AM in reply to: gspiper
No, since we don't know what your customer PC's problem may be, so you have to do a lot of work instead. This almost always works:
1. Uninstall ALL instances of .NET and C++.
2. Manually remove DTV2014 then manually clean up the WIndows Registry of Autodesk products.
3. Use a Windows Registry cleaner to tidy things up.
4. Restart Windows.
5. Reinstall DTV2014. It should inslall the support files it needs, including .NET and C++.
6. Ensure it is running corectly.
7. Start Windows Update and let it hunt for any other needed versions of .NET and C++ the other installed applications need.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
You are not logged in.
Ask the Community
