When I export a .dwg, created with AutoCAD Map 2000, to .pdf in DWG TrueView 2011 I get the following message from Adobe Reader: "Cannot find or create the font "TimesNewRomanPSMT". Some characters may not display or print correctly". What is wrong? What can i do?
Hans Browall
Solved by pendean. Go to Solution.
Click on PROPERTIES button after you select the DWG to PDF.PC3 driver, go to Settings Tab>Custom Properties>and set font handling to CALTPURE ALL or CAPTURE NONE.
Thank you very much Mr Saadallah for your advise. Now I have the most beautiful PDF out of my DWG.
Hans Browall
