When I try to install DWG TrueView 2014, I get the following error:
Setup.exe - Entry Point Not Found
The procedure entry point inflateEnd could not be located in the dynamic link library zlib.dll.
Running Windows 7 (64-bit)
Welcome to the Autodesk Forums!
Did you download the 64bit version for the install?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Do you have .NET 4.0 installed on your machine?
If so it may be worth deleting and then reinstalling prior to trying the DTV install.
If there is any piece of the install you may want to try this program:
REVO UNINSTALLER The free version on its most aggressive setting will get rid of all files.
Use this as the uninstall instead of Windows.
And see if any hanging Registry entries can get cleaned out then try the install again.
