DWG TrueView
New Member
oosterop
Message 1 of 4 (418 Views)
Save profile DWG Trueview 2014
418 Views, 3 Replies
02-21-2014 02:09 AM
We are gona use DWG True View for about 100 users. We also have a netwerk with 60 AutoCAD 2014 engineers. As in AutoCAD we want to make a profile with settings (like plotter settenings of display colors)
I can't find this option in DWG True View 2014.
When I make a modification fot these settings in DWG True View 2014 it will be saved. Because when I start it with another drawing the settings are correct.
I've searches the register and in ini files on the disc, but can't find them.
How to get (import) these setting on the other 100 workstations?
Many thanks in advance.
Regards, Erwin
pendean
Message 2 of 4 (398 Views)
Re: Save profile DWG Trueview 2014
02-22-2014 08:06 AM in reply to: oosterop
The Free Viewer has none of those AutoCAD abilities.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
dgorsman
Message 3 of 4 (383 Views)
02-25-2014 08:44 AM in reply to: oosterop
You need to look a little more closely in the registry.  The structure is the same as for AutoCAD so if you can work with one you can work with the other.  As with all things registry be cautious and backup *before* testing.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
rkmcswain
Message 4 of 4 (369 Views)
02-26-2014 11:12 AM in reply to: oosterop
What dgorsman said. Although profiles are not supported via the Option dialog, you can save and import a lot of the stuff there via a REG file.
For example, the support file search path can be found here:
HKEY_CURRENT_USER\Software\Autodesk\DWG TrueView\Rxx\dwgviewr-xxxx:xxx\Profiles\<<Unnamed Profile>>\General\Support
You are not logged in.
Ask the Community
