• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    DWG TrueView
    New Member
    Removed TrueView 2010--now TrueView 2013 won't install
    836 Views, 1 Replies
    11-27-2012 06:25 PM
    Has anyone had this problem?
    After uninstalling TrueView 2010, I used jv16 Power Tools to clean my registry and then rebooted.
    I downloaded the "SetupDWGTrueView2013_64bit.exe" file for my Win7 64-bit Professional system.
    Ran this file which created an 'Autodesk/DWGTrueViewx64InstallImage' directory containing the installation files.
    Double-clicked the "Setup.exe" file, the User Account Control window opened, I said "Yes" to allow Autodesk to make changes to my computer, and nothing happened.
    I tried running the "Setup.exe" file as an Administrator and even copied the InstallImage files to a new directory. Setup.exe didn't install there either.
    I never get the installation to begin, but just in case, I do have MS Net 4 Extended installed along with SP1 (KB2468871).
    Does anyone have an idea why 'Setup.exe' doesn't run?
    Thanks greatly for your help.
    Jerry
    Please use plain text.
    Active Contributor
    Re: Removed TrueView 2010--now TrueView 2013 won't install
    03-12-2013 10:34 AM in reply to: planckster
    i unsinstalled TrueView 2012, which worked fine, and then couldn't get 2013 to install. i also re-installed Net 4 and SB 2.  still no luck.
