I installed true view
it asked for .NET 4 and then 3.5
installed them and successfully installed the true view.
But now when I try to open the true view it gives me this message (Attached)
does anyone have an idea how to solve this?
1. I have installed and removed it quite a few times
2. No idea why it is "saying" that.
This is why I turned for help here...
Drawing True View
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Remove all .NET and Visual C++ versionf on your PC.
Autodesk recommended uninstall/reinstall procedures are as follows
Uninstall: http://usa.autodesk.com/getdoc/id=TS45252
Ensure the user installing/uninstalling and using the product have enough rights to do so (install and reinstall as local administrator):
Unable to run AutoCAD® as a restricted user http://usa.autodesk.com/getdoc/id=TS1055299
Restart your PC.
Turn off all background running applications: all of them.
Install DTV2014.
Remember to start Windows Update to put back .NET and Visual C++ versions that may be neded by other applications on your PC.
