DWG TrueView
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Problem editing AutoCAD object embedded in excel.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello, I'm running AutoCAD 2008 and Excel 2010. I usually recive embedded dwg files in spreadsheets, and edit them by double click on them.
I didn't have problems until I installed DWG trueview 2010. Then these Ole objects, started being named as DWG TrueView Drawings (instead of Autocad Drawing as before), and can’t be edited double clicking them.
If you try to do this, a message box with the text "Cannot start the source application for this object" pops up.
I tried uninstalling Dwg TrueView 2010, and reinstalling autocad but it didn’t work.
I've also started with a new Excel sheet and new Acad drawing thinking there might be a version incompatability but I still get the same error.
If somebody had the same problem and found a work around, i will apreciate a lot the feedback.
Re: Problem editing AutoCAD object embedded in excel.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am having the same issue with AutoCAD 2008 and Excel 2010.
Any suggestions on how to fix this?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Nope, I tryied almost everything without finding afix, or a workaround.
I Just edited the file with a machine with autocad 2010 and saved it to a *.dwg. No words from Autodesk since AutoCAD 2008 is not supported any more.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
no mention if you tried this,
try changing what opens .dwg files to "AutoCAD DWG Launcher" instead of plain acad.exe if that's what it is set to.
HTH
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Did that work using AutoCAD 2010?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
List of "NOT working" tried solutions:
Setting DWG Launcher o acad.exe as (*.dwg) file default opener.
Uninstalling DWG Trueview.
Change in excel the version of de OLE object.
Change something in the registry (there was a solution for the same problem with trueview 2006 an autocad 2004 or something like that, changing a registry entry, but it doesn't work for cad 2008 / tv 2010).
And a few more than i can't recall
sorry.
But, I didn't try reinstalling autocad, trueview and office all together, because it was much more trouble than install autocad 2010 in another machine and do the convertion there.
We still use autocad 2008 in all our machines because of compatibility issues with other softwars, and hardware limitations
, so all who need to retrieve an embedded dwg on an excel file, goes to our AutoCAD 2010 machine.
