• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    DWG TrueView
    *Fahlin, Robert P.
    Paste to Outlook
    136 Views, 3 Replies
    07-31-2000 07:08 AM
    I can't seem to cut and paste from VVE to Outlook. Works fine with
    exchange, Lotus Notes, and other windows compliant programs, but not
    OutLook.
    Any suggestions?
    Thanks...
    Please use plain text.
    *Support, Autodesk
    Re: Paste to Outlook
    08-09-2000 04:35 PM in reply to: *Fahlin, Robert P.
    Robert,
    What version of Outlook are you using and what operating system? I have
    tried it with outlook 97 and 2000 and both are working fine on Win98.
    Haven't had a chance to check it on Win2000.
    Bill Gilk
    PSG Product Support, Americas
    WW Support & Services, Autodesk
    Discussion Q&A: http://www.autodesk.com/discussion
    > OutLook.
    > Any suggestions?
    > Thanks...
    *Drewes, Terry M.
    Re:
    08-10-2000 11:15 AM in reply to: *Fahlin, Robert P.
    Hi Bill!
    I tried this routine with Outlook98 and WIN NT O-S SP6a and it does not
    work.
    Note-- I am using latest build 129 of VVE.
    However, one can open up MS Paint and paste in the VVE clipboard image,
    then copy it from Paint and then paste in to Outlook98 via Paste Special
    that allows three options:
    [Image]
    And that process works fine! I did the Paste Special with Metafile and the
    appears appears fine in Outlook98. Note! Image copied from VVE is
    what is on the display!
    Sincerely,
    Matocha Associates
    Terry M. Drewes, AIA, IT Coordinator
    "Bill Gilk (Autodesk Support)" wrote:
    > Robert,
    > Bill Gilk
    > > OutLook.
    > > Any suggestions?
    > > Thanks...
    *Support, Autodesk
    Re:
    08-11-2000 12:31 PM in reply to: *Fahlin, Robert P.
    Terry,
    I tried again with Win98 and NT both using Outlook 2000 and have different results on each. In Windows
    98 and Outlook 2000 it copy and pasted fine. In Windows NT4 SP5 and Outlook 2000 it does not work.
    Could do as you stated, copy and paste into paint, then reelect the image and copy and paste into
    Outlook. Looks like an OLE error in Windows NT, but will do more research.
    Bill Gilk
    "Terry M. Drewes" wrote:
    > Hi Bill!
    > work.
    > [Image]
    > Sincerely,
    > Matocha Associates
    > > Robert,
    > > Bill Gilk
    > > > OutLook.
    > > > Any suggestions?
    > > > Thanks...
