DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Operating System Windows 7 Premium Home not supported msg when installing
8 REPLIES 8
Message 1 of 9
4564 Views, 8 Replies
I am trying to install DWG Trueview 2011 32 bit on my computer. I am running Windows 7 Premium Home. The .PDF systems requirements indicates this operating system is supported, but when I install the program I get an error that says This operating system is not supported by DWG Trueview 2011. Not sure what to do....
8 REPLIES 8
Message 2 of 9
It sounds like your trying to install the wrong version. If your running a
64bit Operating System, then you need to install the 64bit version of DWG
TrueView. If it's a 32 bit OS, then you need to install the 32 bit version
of DWG TrueView.
Hope this helps.
Bud Schroeder
AutoCAD Test Development
Autodesk Inc.
"tcrowland" wrote in message news:6392053@discussion.autodesk.com...
sure what to do....
Message 3 of 9
Well that sounds simpe enough. I will try to download the 64 bit version again. I have tried twice but maybe the third time will be a charm. Thanks for the help!
Message 4 of 9
I have tried to run the install three times- I run a 32bit Windows 7 and I have made very sure that I am installing the correct one, and yet- it still does not seem to want to install. Any ideas?
I would greatly appreciatte it, as this is getting more and more aggrivating.
Sam
Message 5 of 9
Same thing here.
Fact 1:
I'm using a computer with a "Win XP 32" O.S.
I installed the "DWG TrueView" soft and I have been using it.
Fact 2:
I have tried to install the very same installer file to a computer with a "Win 7 32" O.S.
I have managed to install DirectX, but failed to install the "DWG TrueView" soft itself.
The log file contents follows:
2010/7/20:10:20:20         enjoy02               ENJOY2                === Setup started on ENJOY2 by enjoy02 ===
2010/7/20:10:20:31         enjoy02               ENJOY2                === Setup ended ===
2010/7/20:10:20:28         enjoy02               ENJOY2                === Setup started on ENJOY2 by enjoy02 ===
2010/7/20:10:21:49         enjoy02               ENJOY2                Install    Microsoft Visual C++ 2008 Redistributable (x64)              Failed                Installation aborted, Result=2
2010/7/20:10:22:31         enjoy02               ENJOY2                Install    Microsoft Visual C++ 2008 Redistributable (x64)              Failed                Installation aborted, Result=2
2010/7/20:10:22:43         enjoy02               ENJOY2                === Setup ended ===
Can someone please help me?
TIA,
Vini
Message 6 of 9
pendean
"...Microsoft Visual C++ 2008 Redistributable (x64)              Failed..."
err, why is it installing the 64bit version in your 32bit OS? It should be installing this one I believe:
http://www.microsoft.com/downloads/details.aspx?familyid=9b2da534-3e03-4391-8a4d-074b9f2bc1bf&displa...
Are you sure Win7 is 32bit? Did you deliberately purchase and install only the Win7 32bit? Very quirky indeed this Win7 business.
Message 7 of 9
Hi Vini,
Where did you find the log file?
Message 8 of 9
Honestly, I do not remember.
I think the error msg itself gave me a hint.
Message 9 of 9
The download page does not offer any choice of download. It would appear that you'll always get the x86 version.
