• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    DWG TrueView
    Member
    Layer Filter Applied In Drawing Not Appearing In Trueview Layer Drop Down
    573 Views, 5 Replies
    02-14-2013 05:27 AM
    On a master plan drawing there were far too many layers, so I created a layer filter to show the vital layers on the drawing that I wanted.
    I, myself, have no problem with accesing the layer filter showing up in the drop down instead of the original full list of layers on regular AutoCAD. However, my collegues who don't have access to regular AutoCAD on their desktop only have access to Trueview.
    When opening this drawing on Trueview, the layer  filter I created is clearly viewable in the layer properties, but when I select the filter it does not apply to the layer drop down. This is not practical for my colleagues with regards to viewing the drawing. I want my layer filter showing up for ease of access to turn specific layers on and off.
    Could anybody please advise me on how to make a layer filter show up on the layer drop down in Trueview, or is this not possible?
    Thanks.
    Please use plain text.
    *Expert Elite*
    pendean
    Re: Layer Filter Applied In Drawing Not Appearing In Trueview Layer Drop Down
    02-14-2013 06:02 AM in reply to: D93J
    Works fine here in DTV2013: I notice you are using DTV2010. Download and test it to confirm at your end before spreading it around.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Member
    02-14-2013 06:22 AM in reply to: pendean
    Thanks, but that's not possible as it's my work's network and cannot download anything onto the network.
    I either need some sort of way to make it work the way I want it to on 2010, or to know if it absolutely is not possible.
    *Expert Elite*
    pendean
    02-15-2013 05:33 AM in reply to: D93J
    You'll have to wait for a DTV2010 user to respond, this is peer support (we are end users like you): based on your testing, it doesn't work (and there are no patches or updates posted for DTV2010) so at least that partially answers your question.
    Or did it use to work at one time and now it does not?
    Either way, you should be engaging your I.T. /Server personnel and discussing your options moving forward.
    Member
    02-15-2013 06:05 AM in reply to: D93J
    Hopefully a DTV2010 user can provide a solution that won't involve a patch/update or download if possible.
    Thanks, it helps knowing it may be as i suspect that there may not be any solution with regards to a simple change of settings.
    That i know of, it never has worked as it does on DTV2013 (how I want it to). Most of our other drawings don't have so many layers. As this is a master plan the filter had to be created for ease of use. You can manually view the filter in layer properties, but not the drop down, which would be a little more convenient for a less savvy DTV/AutoCAD user.
    We have to have a very secure network and our I.T are extremely strict with what we put on to the network, so it may be a dead end unless we can twist their arm.
    Thanks again.
    Distinguished Mentor
    ampster
    02-15-2013 06:58 AM in reply to: D93J
    Considering how often people post in this forum, you might be waiting awhile for a 2010 user to reply!
    Ditto on Dean's suggestion about working with your local IT to go over what possible solution you and any other employee has to obtain software on the Internet that you are not allowed to download and/or install yourself.
    That's ridiculous if they don't have a process in place!
    As for DWG Trueview 2011, it works as intended...at least it works in the manner I was able to figure out how to do it in Acad 2011.
    Highlight the filter in the Layer Properties Manager window, right click on it and choose "Isolate Group" > "All Viewports" to hide all other layers except the ones in this filter.  Then to turn them on, right click on the "All Used Layers" filter and choose "Visibility" > "Thawed" to turn all layers back on.
    HTH
