I've tried to install DWG True View 2014. He exited with an error saying Internet Explorer 7 SP1 or later is missing. So he is wrong. Internet Explorer 9 is installed. I getting this error also on Windows 8 Clients with IE10 installed.
Any Ideas`?
mfg Andreas
IE9 & 10 are the only browsers installed. So no other default browser defined...
Tried sooooooooo many times to load this but keep getting internet connection failed? Don't understand this has I've done this wired not wireless. I've tried on numerous machines and the same error comes up.
I need to get this sorted as I need to roll this out onto numerous machines. I'm not IT specialised only a CAD technician, my company IT haven't a clue about CAD. So any help will be much appreciated.
machine running Windows 7 64bit.
it seems not every Client in my environment has this problem. Installed it on another 10. Only 1 shown up with the error. The other are working fine.
Greetings
Didnt mean to hijack this thread but this came up on the DWG viewers search. Just needed some help from the experts out there. Will try your solution.
Thanx
IE9 is installed on the most of the Clients. And Its the only browser so it should be dafault
HKEY_CLASSES_ROOT\http\shell\open\command says IE. It will monitor the problem. I have a DWG 2013 software packet in the back...
Greetings
