• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    DWG TrueView
    New Member
    aetius80
    Installing AutoDesk 2012 DWG TrueView on Citrix?
    1369 Views, 4 Replies
    11-21-2011 02:39 AM
     Has anyone managed to DWG TrueView 2012 working in Citrix Xenapp 4.5?
    The program installs, runs fine as an administrator, but not an end user.
    If someone has got this to work successfully I'd love to hear from them.
    thx
    Please use plain text.
    New Member
    MatthewSn
    Re: Installing AutoDesk 2012 DWG TrueView on Citrix?
    11-21-2011 06:19 AM in reply to: aetius80
    Same problem here, albeit running Xenapp 5.5 (soon 6). Any help would be much appreciated. There was one thread I found (that of course I can't find again) that recommended copying over some Autodesk application folders from the administrative user's profile, and modifying a whole boatload of registry keys, which I am loathe to do for testing purposes, especially since the instructions were for 2011, not 2012.
    New Member
    GillBates
    11-23-2011 01:33 AM in reply to: MatthewSn
    I used Citrix Streaming Profiler 6.5.
    It runs fine locally in the profiler, as streamed application it reports not .net FW v4.0.30319. But it's installed definitely.
    Any idea what Trueview checks on startup ?
    Gill
    New Member
    Bandit2010
    02-03-2012 11:58 AM in reply to: aetius80
    We have the same instalation type on a Windows terminal server running for more than a year and the only way to make it work is include the user, in the local administrator group. If any one does have a better solution,I would appreciate it.
    Active Contributor
    09-05-2012 05:54 AM in reply to: aetius80
    Did anyone try 2013 DWG TrueView on Citrix yet?  Does it work any better?
