Hi everyone,
I ve got a huge dwg (in dimension 17950 on 2970). If i pick standard export, i have only a piece of it, which corresponds to the sheet displayed on the screen). I d like to export everything in a single pdf, how i can do that ?
Best
Guillaume
Solved by pendean. Go to Solution.
Hi, Guillaume.
I wonder did you mean to convert pdf to dwg by saying "export DWG to PDF with a format bigger than standard A4" ?
What if I cant see the default pdf driver?
