Today I was asked to install Trueview on several PCs here and as such I went ahead to download it so I could do so...
But these were some PCs from our TD, which (tell me that they) need to stick to XP because of PLC support.
Which explained why TV2015 wouldn't install... ( no XP supported)
So my request is: where can I still get Trueview 2014?
I need it in 32 and 64 bit.
Solved by pendean. Go to Solution.
Thanks.
We know that XP will/is no longer supported... but we have production machines which are a lot older then XP is, that use even older operating systems (OS/2 for example).
The PCs with XP are kept to be able to communicate with those machines, but are kept off the internet and such.
Not a brilliant solution, but I guess that if anyone offers you a x million $ machine at any time using any current OS of that time... you apparently don't think about the fact that the machine is going to last a whole lot longer then that operating system is going to last. (and yes, we all should've picked Unix way way back, but that's crying over spilt milk).
I would sugesst you request for one from www.wanetelecoms.com
Have got nearly every software i wanted from there.
Good luck
