• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    DWG TrueView
    Valued Contributor
    Error - "is running out of system memory"...Please help!
    777 Views, 2 Replies
    12-04-2012 10:23 AM
    I'm running DWG TureView 2013 and keep having problems opening up one 6mb DWG file.  It gets to 69% and freezes and gives me an error message that says "DWG TrueView is running out of system memory.  Continuing the current operation may result in program failure or loss of data. Do you want to cancel the current operation?"
    This only seams to happen to this one file when I try and open it in TrueView and I'm trying to convert it down to ACA 2007 or ACA 2004 so I can use it on our ACA 2008 program.  When I do convert it in TrueView without actually opening it, it creates a DWG file to open in ACA, but that too freezes at 85% so I can't open that either.
    Does anyone know how I can fix this issue and get this file open and converted down to a usable file for us?
    FYI, I'm running Windows 7 32-bit.
    Thanks for the help.
    Please use plain text.
    pendean
    Re: Error - "is running out of system memory"...Please help!
    12-05-2012 04:45 AM in reply to: dficarra
    See this tip from Autodesk: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2862058&linkID=9240617
    Most likely though, you have just have a corrupt DWG file. Ask the file creator to knock the file down for you if that's an option, they will need to use -EXPORTTOAUTOCAD command (there is a dash in the name) and not SAVEAS command.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Valued Contributor
    12-06-2012 09:16 AM in reply to: pendean
    I contacted the file creator and had him clean it up and purge some of the content out of it and the one he re-sent worked fine.  Probably was just an issue with that one file, but we'll see if I get another one down the road that does the same thing.
    Thanks Dean.
