DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Error 1907. Could not register font .
4 REPLIES 4
stanektool
7010 Views, 4 Replies
I've installed TrueView on a new Win7 Pro x64 computer.  I installed the software as Domain Administrator with no problems.  When I log into another user on the domain and attempt to start TrueView I get the error
"Error 1907.  Could not register font .  Verify that you that you have sufficient permission to install fonts, and that the system supports this font."
To solve the problem I had to run a repair install logged in as the user that wants to run TrueView.
Start Button -> control Panel -> Programs and Features -> Select TrueView -> right click Uninstall -> Select Repair and Reinstall.
-Craig
Tags (1)
4 REPLIES 4
yee.arthur
in reply to: stanektool
Facing similar issue. Is there any workaround / solution to this? What fonts is the application trying to create? Can we push such fonts via GPO? Users are non administrators status.
pendean
in reply to: yee.arthur
m_latz
With which version of TrueView did you receive that error ?
regards
Markus
stanektool
in reply to: m_latz
Look at the date on the post. 🙂  The previous spam reply gave it a bump, unfortunately.
