I've installed TrueView on a new Win7 Pro x64 computer. I installed the software as Domain Administrator with no problems. When I log into another user on the domain and attempt to start TrueView I get the error
"Error 1907. Could not register font . Verify that you that you have sufficient permission to install fonts, and that the system supports this font."
To solve the problem I had to run a repair install logged in as the user that wants to run TrueView.
Start Button -> control Panel -> Programs and Features -> Select TrueView -> right click Uninstall -> Select Repair and Reinstall.
-Craig
Facing similar issue. Is there any workaround / solution to this? What fonts is the application trying to create? Can we push such fonts via GPO? Users are non administrators status.
With which version of TrueView did you receive that error ?
regards
Markus
Look at the date on the post. 🙂 The previous spam reply gave it a bump, unfortunately.
