I've installed TrueView on a new Win7 Pro x64 computer. I installed the software as Domain Administrator with no problems. When I log into another user on the domain and attempt to start TrueView I get the error
"Error 1907. Could not register font . Verify that you that you have sufficient permission to install fonts, and that the system supports this font."
To solve the problem I had to run a repair install logged in as the user that wants to run TrueView.
Start Button -> control Panel -> Programs and Features -> Select TrueView -> right click Uninstall -> Select Repair and Reinstall.
-Craig
Facing similar issue. Is there any workaround / solution to this? What fonts is the application trying to create? Can we push such fonts via GPO? Users are non administrators status.
Look at the date on the post. 🙂 The previous spam reply gave it a bump, unfortunately.
