DWG TrueView
Active Member
slcastner
Message 1 of 19 (15,984 Views)
Drawing file is not valid
15984 Views, 18 Replies
02-26-2008 01:46 PM
When attempting to open AutoCAD 2008 .dwg files with DWG TrueView 2008, I am receiving a series of errors, beginning with, "Drawing file is not valid." The series of error messages is shown in the attached .pdf file.
The files that are reported missing (i.e., AecBaseenu.dll) are in fact present in /Program Files/DWG TrueView 2008
Older AutoCAD .dwg files (2004) open properly.
I uninstalled and reinstalled DWG TrueView 2008 three times, with no change in the error messages.
Please let me know how to fix.
Steve Castner
*Dean Saadallah
Message 2 of 19 (15,984 Views)
Re: Drawing file is not valid
02-26-2008 04:57 PM in reply to: slcastner
Post the DWG file...
Dean Saadallah
http://LTisACAD.blogspot.com
Add-on products for LT
http://www.pendean.com/lt
Active Member
slcastner
Message 3 of 19 (15,984 Views)
02-26-2008 05:10 PM in reply to: slcastner
One is attached. More if you like.
TIA for your help.
*Scott Sheppard - Autodesk
Message 4 of 19 (15,984 Views)
02-26-2008 06:20 PM in reply to: slcastner
I got the error message "Drawing file is not valid" when I opened it with
AutoCAD 2009. Perhaps the drawing file is not valid?
wrote in message news:5859355@discussion.autodesk.com...
TIA for your help.
Active Member
slcastner
Message 5 of 19 (15,984 Views)
02-26-2008 07:12 PM in reply to: slcastner
Here is one more. Would you please try it? If it does not open, I will go to the source.
Thank you.
*R.K. McSwain
Message 6 of 19 (15,984 Views)
02-28-2008 11:36 AM in reply to: slcastner
> Thank you.
Wetland Delineation Data.dwg opens fine.
34 errors found when you run AUDIT.
ALTA OR KOHLWEY.dwg is not a drawing file.
It's just a file filled with zeros that happens to have a
.DWG extension.
R.K. McSwain
http://rkmcswain.blogspot.com
Active Member
slcastner
Message 7 of 19 (15,984 Views)
02-28-2008 12:20 PM in reply to: slcastner
All my .dwg files from that batch open properly on two XP machines but do not open properly on two Vista machines. I suppose the first file that I sent to you could have been corrupted during the transfer. For now, we are using XP machines when we need to run DWG TrueView. Maybe an automatic Windows update will fix it overnight. Thanks for your efforts.
New Member
Rifardo
Message 8 of 19 (15,984 Views)
04-25-2008 11:44 AM in reply to: slcastner
I just installed DWG TrueView and I'm not being able to open my AutoCAD files. I'm getting the error: "Drawings file is not valid" Any ideas on how to fix this problem? I'm using AutoCAD 2008 & Windows XP.
New Member
bhavesh_roshiya
Message 9 of 19 (15,984 Views)
05-11-2010 03:59 AM in reply to: slcastner
Autocad dwg, show error
dwg file is not valid
Pls send response Edited by: bhavesh_roshiya on May 11, 2010 12:02 PM
*A+P
Message 10 of 19 (15,986 Views)
05-11-2010 11:31 AM in reply to: slcastner
It's not recoverable. Time to look for your .bak file, rename to .dwg and
use this.
Paul
wrote in message news:6389060@discussion.autodesk.com...
Pls send response
You are not logged in.
Announcements
Need installation help?
Ask the Community
