08:00 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Recentnly, I installed a 64-bit version of DWG True View. Now, when I go to open a DWG file, Abobe Reader opens and displays the following message:
"Adobe Reader could not open 'xxx.dwg' because it is either not a supported file type or because the file has been damaged."
Is there any way to change the settings to enable DWG files to open through DWG True View, as opposed to Adobe Reader? Is there an AC Launcher associated with True View where I would make the setting changes? If so, where is the AC Launcher file located in True View?
Thanks.
