DWG TrueView
Member
unfamiliar2
Message 1 of 4 (1,297 Views)
DWGs Trying to Open in Adobe, not True View
1297 Views, 3 Replies
01-04-2013 08:00 AM
Recentnly, I installed a 64-bit version of DWG True View.  Now, when I go to open a DWG file, Abobe Reader opens and displays the following message:
"Adobe Reader could not open 'xxx.dwg' because it is either not a supported file type or because the file has been damaged."
Is there any way to change the settings to enable DWG files to open through DWG True View, as opposed to Adobe Reader?  Is there an AC Launcher associated with True View where I would make the setting changes?  If so, where is the AC Launcher file located in True View?
Thanks.
philip.s
Message 2 of 4 (1,293 Views)
Re: DWGs Trying to Open in Adobe, not True View
01-04-2013 09:13 AM in reply to: unfamiliar2
Hello Stephen,
You're going to need to make sure that DWG True View is setup as the default program for .dwg files. To do so, open your Control Panel -> Programs -> Default Programs -> Set Associations / Associate a file type or protocol with a program -> .dwg -> Change program.
Hope that helps and please accept as a solution if this fully resolves the issue, or reply with additional specifics as needed.
Philip Schmelzer
Member
unfamiliar2
Message 3 of 4 (1,286 Views)
01-04-2013 10:09 AM in reply to: philip.s
Peter,
I knew that it had to be something simple.  Thanks for the help.
Stephen
Member
unfamiliar2
Message 4 of 4 (1,285 Views)
01-04-2013 10:10 AM in reply to: unfamiliar2
*Philip.  My mistake.
You are not logged in.
Ask the Community
