Hi, I'm an IT support who encounter rather peculiar issue with DWG TrueView 2013
When a user was plotting certain area using DWG trueview 2013, it always revert to the default plot area. However, if user plot any other places (still the same file) it was ok.
What could be the issue?
I have tried uninstall the DWG TrueView 2013 and installed the 2014 version, and still encounter the same issue.
What could go wrong?
Welcome to the Autodesk Forums!
Can you post the file?
Also, step by step what the user is doing to create the plot.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
