style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
"Dyehouse1" <When
href="mailto:w.dyehouse@parkair.co.uk">w.dyehouse@parkair.co.uk> wrote
in message
href="news:ef57d47.-1@WebX.SaUCah8kaAW">news:ef57d47.-1@WebX.SaUCah8kaAW...
I click on a WWW link to a DWG file all I see is a tiled VV icon in the
browser window. However if I click REFRESH numerous times it seems to load it
about 1 in 20 times. Is this a BIG BUG noone but me seems to have seen?
I need the ability to view DWG files from a link on a WWW browser - if VV
won't do this successfully can any recommend another free plug-in or viewer as
we want to use DWG files with MS Tahoe when it is released.
Any replies to
W.Dyehouse@parkair.co.uk
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"Dyehouse1" <When
in message
Any replies to
"mimo" <mikem@pandell.com>I
wrote in message
href="news:ef57d47.7@WebX.SaUCah8kaAW">news:ef57d47.7@WebX.SaUCah8kaAW...
have exactly the same problem. Voloview will only display this hideously ugly
tiled VV icon. Hitting refresh very rarely works. The only way to have it
actually display the drawing is to re-install voloview - which only works the
first time.
We have tried numerous methods of instantiating the control - all with the
same result. Attempting to load drawings into voloview itself directly after
downloading will often (but not always!) result in the application simply
crashing with no message.
I have also tried having voloview open in the background while trying to
launch a drawing in the browser. This results in the browser and voloview both
locking up.
I am running windows 2000 IE 5.5., although we are experiencing the problem
on other platforms as well.
I need a solution, or an alternative control ASAP.
Mike M.
"W.J. Roes" <
href="mailto:w.j.roes@zonnet.nl">w.j.roes@zonnet.nl> wrote in message
href="news:88BE460A67FD2571C7FBD1690AD673B9@in.WebX.SaUCah8kaAW">news:88BE460A67FD2571C7FBD1690AD......
Are you using IE? IE5.5? IE5.5 + SP? On Win2000?
I seem to have the exact same problem.
"Dyehouse1" <When
wrote in message
it about 1 in 20 times. Is this a BIG BUG noone but me seems to have seen?
as we want to use DWG files with MS Tahoe when it is released.
Any replies to
"Greg Wesner (autodesk Inc.)" <
href="mailto:greg.wesner@autodesk.com">greg.wesner@autodesk.com> wrote
in message
href="news:276655E74187A3DAE336DEF170C981E7@in.WebX.SaUCah8kaAW">news:276655E74187A3DAE336DEF170C......
I would like to see a sample html file or any
other method you used of instantiating the control.
Greg.
wrote in message
ugly tiled VV icon. Hitting refresh very rarely works. The only way to have
it actually display the drawing is to re-install voloview - which only works
the first time.
the same result. Attempting to load drawings into voloview itself directly
after downloading will often (but not always!) result in the application
simply crashing with no message.
both locking up.
problem on other platforms as well.
Mike M.
"Scott Sheppard" <
href="mailto:scott.sheppard@buzzsaw.com">scott.sheppard@buzzsaw.com>
wrote in message
href="news:ECF5E1CB44E1616E2A11751C4BED6357@in.WebX.SaUCah8kaAW">news:ECF5E1CB44E1616E2A11751C4BE......
I am having the same problem on Windows 2000 with
IE 5.5 and the latest updates from the Microsoft site. I never knew refresh
would get it to load. I will try that and see if I have the exact same
problem.
"W.J. Roes" <
href="news:88BE460A67FD2571C7FBD1690AD673B9@in.WebX.SaUCah8kaAW">news:88BE460A67FD2571C7FBD1690......
Win2000? I seem to have the exact same problem.
"Dyehouse1" <When
wrote in message
VV won't do this successfully can any recommend another free plug-in or
viewer as we want to use DWG files with MS Tahoe when it is released.
Any replies to
"Scott Sheppard" <
wrote in message
href="news:0610AC2B092235F8E0D102D0070A5FE9@in.WebX.SaUCah8kaAW">news:0610AC2B092235F8E0D102D0070......
I tried hitting refresh 128 times (using the f5
key for Internet Explorer) and mine would never show up. I was using a test
HTML page that looked like:
size=2><html>
<title>campus.dwg</title>
<body>
<p>
campus.dwg
</p>
<object
classid="clsid:8718C658-8956-11D2-BD21-0060B0A12A50"
width=400
height=300>
<param
name="src"
value="campus.dwg">
<embed
width=400
height=300
src="campus.dwg">
</embed>
</object>
</body>
</html>
"Scott Sheppard" <
wrote in message
href="news:ECF5E1CB44E1616E2A11751C4BED6357@in.WebX.SaUCah8kaAW">news:ECF5E1CB44E1616E2A11751C4......
with IE 5.5 and the latest updates from the Microsoft site. I never knew
refresh would get it to load. I will try that and see if I have the exact
same problem.
"W.J. Roes" <
message
href="news:88BE460A67FD2571C7FBD1690AD673B9@in.WebX.SaUCah8kaAW">news:88BE460A67FD2571C7FBD16......
"Dyehouse1" <When
wrote in message
load it about 1 in 20 times. Is this a BIG BUG noone but me seems to
have seen?
if VV won't do this successfully can any recommend another free plug-in
or viewer as we want to use DWG files with MS Tahoe when it is released.
Any replies to
"Dyehouse1" <Good
in message
href="news:ef57d47.3@WebX.SaUCah8kaAW">news:ef57d47.3@WebX.SaUCah8kaAW...
Luck!
You will have to refresh about oooh 25 times AT
LEAST.
"Scott Sheppard" <
wrote in message
size=2><html>
<body>
<p>
campus.dwg
</p>
<object
width=400
height=300>
<param
name="src"
value="campus.dwg">
<embed
width=400
height=300
src="campus.dwg">
</embed>
</object>
</body>
</html>
"Scott Sheppard" <
wrote in message
same problem.
"W.J. Roes" <
message
"Dyehouse1" <When
wrote in message
have seen?
Any replies to
"Geoff Williams" <
href="mailto:williams@parkinfm.com">williams@parkinfm.com> wrote in
message
href="news:5D5B3F3E05D55B1C7154BC092F5177EA@in.WebX.SaUCah8kaAW">news:5D5B3F3E05D55B1C7154BC092F5......
Just to add to this discussion. Scott, if I
want to see a black background on the web I have to do one of two things:
script the background to be black; or have VVE running in the background and
have it's default settings for background set to black. If I close VVE
in the background the next drawing that I load will have the tiled Logo image
instead of a drawing. Is there another build coming or are we stuck to
develop for this one?
Geoff
"Scott Sheppard" <
wrote in message
href="news:0610AC2B092235F8E0D102D0070A5FE9@in.WebX.SaUCah8kaAW">news:0610AC2B092235F8E0D102D00......
size=2><html>
<body>
<p>
campus.dwg
</p>
<object
width=400
height=300>
<param
name="src"
value="campus.dwg">
<embed
width=400
height=300
src="campus.dwg">
</embed>
</object>
</body>
</html>
"Scott Sheppard" <
wrote in message
href="news:ECF5E1CB44E1616E2A11751C4BED6357@in.WebX.SaUCah8kaAW">news:ECF5E1CB44E1616E2A11751......
same problem.
"W.J. Roes" <
message
href="news:88BE460A67FD2571C7FBD1690AD673B9@in.WebX.SaUCah8kaAW">news:88BE460A67FD2571C7FBD......
"Dyehouse1" <When
wrote in message
the browser window. However if I click REFRESH numerous times it seems
to load it about 1 in 20 times. Is this a BIG BUG noone but me seems
to have seen?
plug-in or viewer as we want to use DWG files with MS Tahoe when it is
released.
Any replies to
