DWG TrueView
Active Member
crozza
Message 1 of 13 (3,629 Views)
DWG Trueview on Windows 2008 R2 server
3629 Views, 12 Replies
10-17-2012 04:19 AM
We have DWG Trueview 2013 on Windows 2008 R2 Remote Desktop servers.
However, we don't seem to be able to open .dwg files?? Only .dwx and .dwf files. Should we not be able to open .dwg files given the name of the programme? If we cannot open these files then we need to get another programme installed. I installed it locally and it installed DWG Trueview 2012, and it also installed a plugin of Autdesk Design Review 2013, which allows us to open .dwg files.
Advice appreciated!
Many thanks,
Crozza
pendean
Message 2 of 13 (3,623 Views)
Re: DWG Trueview on Windows 2008 R2 server
10-17-2012 06:36 AM in reply to: crozza
Not a supported OS may have something to do with it: http://images.autodesk.com/adsk/files/dwg_trueview_system_requirements.pdf
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Member
crozza
Message 3 of 13 (3,620 Views)
10-17-2012 06:46 AM in reply to: pendean
Thanks for that.
Is there something we can use as a dwg viewer on the Remote Desktops? This is where all of our files are saved you see. I can install locally for users but opening 'offline' as it were is a bit long winded for them.
Active Member
crozza
Message 4 of 13 (3,615 Views)
10-17-2012 07:26 AM in reply to: pendean
Sorry, my mistake.
Its a .DWF file that we need to be able to open that is currently not possble in DWG Trueview 2013 on Windows 2008 Server. A .dwg can be opened.
Many thanks,
Crozza
*Pro
ampster
Message 5 of 13 (3,608 Views)
10-17-2012 07:53 AM in reply to: crozza
then you will need Raster Design however I don't know if what you are doing is supported (remote server or O.S.)
pendean
Message 6 of 13 (3,603 Views)
10-17-2012 08:23 AM in reply to: crozza
Design Review opens DWF files, no Trueview: same system requirements for both programs however.
Active Member
crozza
Message 7 of 13 (3,583 Views)
10-18-2012 01:19 AM in reply to: crozza
Sorry to respond with further questions. Autodesk Design Review certainly looks like the software we require installing.
However, I cannot see anything that suggests compatibility with Windows 2008 r2 servers, and our hosting company is not keen to install something which might not be stable due to incompatbility.
Is there a Windows 2008 server version of Autodesk Design Review? I am struggling to find any such thing on the Autodesk site?
Thanks.
pendean
Message 8 of 13 (3,579 Views)
10-18-2012 05:17 AM in reply to: crozza
No, the version posted is the version available: there is not "other" hidden version out there.
So what is it you actually want to do here wiyth the software? You seem very vague about answering questions: Win2008 Server is not an end user OS. Elaborate, there is no wrong answer, just the one you really need (whihc my guess is nothing you've asked so far).
If that's all you have, and you are an end user on a Server OS running end-user applications, someone at that firm sure like to waste money. Perhaps that's the case?
Active Member
crozza
Message 9 of 13 (3,574 Views)
10-18-2012 05:19 AM in reply to: pendean
Ok thanks pendean.
Is it likely to work ok on the Windows 2008 r3 server or may there be some instability / incompatibility issues?
Many thanks for all your help!
Active Member
crozza
Message 10 of 13 (3,565 Views)
10-18-2012 07:25 AM in reply to: pendean
Sorry Pendean, I've only just seen this post fully (busy day).
I've just run some cmd prompts, and the OS is as follows:
OS Name:                   Microsoft Windows Server 2008 R2 Standard
OS Version:                6.1.7601 Service Pack 1 Build 7601
We are a construction company who get sent files, and these can include .dwf, .dwg, and other CAD drawing files. This is a great bit of kit that we want to be able to use to view and print them / save them as .pdf's.
Sorry if I have been vague previously. Hope that helps clarify.
Crozza
You are not logged in.
Ask the Community
