DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
DWG Trueview 2014 Operating System not supported
5 REPLIES 5
mariegrem
1147 Views, 5 Replies
Okay, I have not seen a solution yet for DWG Trueview 2014 not installing with the error message "Operating System not supported". I have tried everything that I have seen in the community and still can't get past this issue. I am running on a 64 bit system and have removed everything associated with AutoDesk from my PC. I have the latest versions of everything required (.NET, Windows 7 Professional, IE, etc.) and still can't get this to work. Any help would be greatly appreciated.
5 REPLIES 5
dgorsman
in reply to: mariegrem
Most common problem would be using a 32-bit installer with a 64-bit operating system, or vice versa.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
mariegrem
in reply to: dgorsman
Using a 64-bit installer on a 64-bit system.
dgorsman
Interesting.  Just for shiggles, try the 32-bit installer.  If that still fails I recommend posting in the Installation board.  You'll get more help with this specific problem there.
mariegrem
Tried the 32-bit installer, didn't work. I will post on board you suggested.
pendean
Check the name of your file that you downloaded: the DTV downloader on the website is stuck at only downloading the 32bit version right now, regardless of what you pick from the pulldown menu.
