DWG TrueView
Member
RikardStrand
Message 1 of 5 (13,951 Views)
DWG Trueview 2013 silent installation on different path (Windows 7)
13951 Views, 4 Replies
05-22-2012 01:19 PM
I'm trying to do a silent installation of the DWG Trueview 2013 software on workstations (Windows 7, 64bit). I have edited the files
..\setup.ini
..\x64\dwgviewr\Setup\setup.ini
I have only changed "INSTALL_PATH"
  • from "INSTALL_PATH=%programfiles%\AutoDesk"
  • to "INSTALL_PATH=D:\Win32\AutoDesk"
If I run setup.exe manually the path is correct and the application installs to
"D:\Win32\Autodesk\DWG TrueView 2013\dwgviewr.exe"
But if I run silently (setup.exe /w /q /i setup.ini) the application defaults to original directory
"C:\Program Files\Autodesk\DWG TrueView 2013\dwgviewr.exe"
How can I resolve this so I can run the silent installer and that it "respects" my "INSTALL_PATH" parameter in setup.ini?
Rikard Strand, Norway
Active Contributor
zride91
Message 2 of 5 (12,544 Views)
Re: DWG Trueview 2013 silent installation on different path (Windows 7)
08-07-2012 07:37 AM in reply to: RikardStrand
Rikard,
Did you ever get this figured out?  I am also having troubles silently installing DWG TrueView.
Dave
Member
RikardStrand
Message 3 of 5 (12,522 Views)
08-07-2012 11:09 PM in reply to: zride91
No - I didn't figured out how to change the path.
The silent installation works (using Microsoft SCCM 2007 R2) but I need to use the default path.
Would like to be able to change the path so I have all software packages on the same path on my client systems.
idubail
Message 4 of 5 (10,384 Views)
12-07-2012 04:19 AM in reply to: RikardStrand
Use this command line :
"C:\...\setup.exe" /w /t /l /q "C:\...\setup.ini"
But I cannot avoid shorcut on the Desktop...
New Member
gerrit.voorn
Message 5 of 5 (1,848 Views)
02-14-2014 12:18 AM in reply to: idubail
Thanks idubail,
"C:\...\setup.exe" /w /t /l /q "C:\...\setup.ini" works create
If you want to avoid a shortcut on your desktop, set de parameter in setup.ini from your source folder "CREATE_DESKTOP_SHORTCUT= to NO else....
You are not logged in.
Ask the Community
