DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
DWG Trueview 2013 crashes when plotting
4 REPLIES 4
jacquesbenoit
3123 Views, 4 Replies
I have a system that crashes when you try to plot a drawing from DWG Trueview 2013.
System info:
Windows 7, 64-bit
DWG Trueview 2013, 64-bit
Jacques
4 REPLIES 4
pendean
in reply to: jacquesbenoit
All printing tasks? Or just when you aim for an HP printer at 11x17 paper?
Plotting to what?
jacquesbenoit
in reply to: pendean
Interesting, it only crashes plotting to the HP using 11x17 paper. If I select letter on the HP, Adobe PDF, or use the Savin Printer/Copier it works fine.
Jacques
pendean
Win7 64bit and HP are the problem then, known issue since Win7 64bit debuted: you need to download and install HP's Universal Driver for Win7 64bit and use it exclusively.
Thank you for the information.
-Jacques
