HKEY_USERS\.DEFAULT can be used for new users on a machine.
For existing users you really have to modify HKEY_CURRENT_USER but that
could be done via loginscript, GPO or the like.
Another hack is to modify the MSI with Orca so it works as expected.
See also
http://blog.shijaz.com/2007/06/modify-users-registry-hive-without.html
Jimmy Bergmark
JTB World - CAD software, development and consulting
Owner/Developer
http://www.jtbworld.com
http://blog.jtbworld.com
AutoCAD Automation Tools
http://www.jtbworld.com/autocad_automation_tools.htm
AutoCAD 2009
http://www.jtbworld.com/autocad2009.htm
"R.K. McSwain" skrev i meddelandet
news:5907452@discussion.autodesk.com...
> bzwart wrote:
>> Well this is a big deal to some businesses. We support 25,000
>> computers across over 1000 locations globally and require
>> DWG and DWF viewing software on many of these computers.
> Just got back from out of town... Any new news on this
> front? We are tiny compared to you but I still don't want to
> go sit down in front of 50 machines to perform manual
> installs....
> Here is another problem.
> We install new software while logged on as administrator.
> The only way (beyond manually monkeying around in OPTIONS)
> to control paths, etc. is to modify the registry where the
> default profile is stored. Since this is stored in HKCU, you
> have to import the REG file while logged on as the current
> user (for each and every user on the machine).
> There needs to be a way to set profile defaults AT INSTALL
> TIME, that will apply to each user that logs on in the future.
> R.K. McSwain
> http://rkmcswain.blogspot.com
