DWG TrueView
Member
Message 1 of 5 (1,397 Views)
DWG TrueView Download
1397 Views, 4 Replies
06-12-2013 09:28 PM
I've tried for the last three months to get DWG Trueview (2014) to install correctly.  I'm running Win7 32bit, and my computer fits all the system requirements.
It will get to the Self-Extractor, and hang at 23 seconds left.  I can leave it all day, and it never finishes.  Anyone else having the same issue?
Joshua Tapp
Joshua Tapp
Charles_Shade
Message 2 of 5 (1,382 Views)
Re: DWG TrueView Download
06-13-2013 05:29 AM in reply to: Tapp_Joshua
Is there a particular file name that the installer is hanging on?
Is there a piece of the File there? Do you see a Trueview folder on the C drive or nothing?
If so try this software and see if you can delete those:
REVO UNINSTALLER The free version on its most aggressive setting will get rid of all files.
Use this as the uninstall instead of Windows.
You could try a System Restore back to prior to the first attempt to install.
If not I would try cleaning the registry of any installed TrueView files but that will be intensive to say the least.
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
New Member
Message 3 of 5 (1,150 Views)
08-06-2013 06:10 AM in reply to: Tapp_Joshua
Joshua,
    I have the same issue at my house Win7 32-bit version. I could not get Dwg TruView 2014 software to install correctly. Were you able to get this issue resolved?
Doug
New Member
Message 4 of 5 (771 Views)
09-30-2013 06:47 AM in reply to: Tapp_Joshua
Se ajudar  ...
Após quase um mês tentando, descobri o que estava travando a extração (pelo menos no meu caso): Macafee anti-vírus.
Tive que remove-lo para a extração não travar. Após a remoção do Macafee, a extração ocorreu normalmente e a instalação também. Depois reinstalo o anti-vírus.
If it helps ...
After almost a month trying to discover what was waging extraction (at least in my case): Macafee anti-virus.
I had to remove it for the extraction does not crash. After removal of Macafee, the extraction and installation normally also occurred. Then reinstall the anti-virus.
Charles_Shade
Message 5 of 5 (751 Views)
10-01-2013 05:11 AM in reply to: j_alefbitencourt
Turning off Antivirus programs is smart installing for all programs that you need to add to your system.
I need to remember to add that piece of info to the quiver.
You are not logged in.
Ask the Community
