DWG TrueView
New Member
Message 1 of 2 (781 Views)
DWG TrueView + Design Review 2012 in Microsoft App_v
781 Views, 1 Replies
01-30-2013 06:46 AM
We need to run DWG True View 2012 + Design Review 2012 in Win7 64bits environment using Microsoft App_v 4.6 SP2.
Both packages from AUtodesk-download install ok (DR 2012 as 32bits) and seem to run ok, except for:
- DR can not open dwg-files (conversion-process to dwf not started)
- TV can export dwf/dwfx but cannot find/open DR for direct viewing dwf.
Looks like both packages can not find each other.
dll's required all are present, file-extensions point to the correct default programs.
Running the same install on non-App_v does not have these problems.
Any user experienced similar problems?
Thx,
Heddo Klandermans
HawarIT
New Member
djv659
Message 2 of 2 (194 Views)
Re: DWG TrueView + Design Review 2012 in Microsoft App_v
12-20-2013 08:52 AM in reply to: hdklandermans
Same problem on VMware. would really like a solution since our users use this feature so that they can measure within a dwg drawing by converting it to a dwf. Even in a non-virtual environment the conversion is flakey. OS is Windows 7 64 bit.
Dennis
IT Support
You are not logged in.
Ask the Community
