DWG TrueView
Message 11 of 13 (1,187 Views)
Re: DWG TrueView 2013 crash after loading DWG
08-12-2013 10:14 AM in reply to: elliott.pointer
Good day Elliot.
How did you added vcomp100.dll  file ? Was it only copy-paste sort of solution?
Also everybody:
A user of mine is experiencing something similar: When he opens a dwg file directly, Autocad starts with no problem. When he opens it from the start menu. After closing the file, he is not able to open Autocad from the start menu without any error message.
Do you think it has to be something with target field of the start menu executable? Or how can this be solved?
He is using AutoCAD 2013.
Thanks for your help in advance.
Eunice Chagoya
Member
Message 12 of 13 (1,178 Views)
08-13-2013 12:53 AM in reply to: eunice.chagoya
Yes, I just added it to the virtual file system at the end of the package. So essentially just a copy and paste into the virtual system32.
Hope that helps.
Thanks.
DuncanBrannan82
Message 13 of 13 (1,024 Views)
09-09-2013 09:16 AM in reply to: elliott.pointer
I recently came across this issue...
To get round it i applied the /nohardware switch to the DWG Trueview shortcut and applied the change.
Once i did this, i could successfully open DWG Trueview and open a DWG file without the program bombing out and reporting the UPITOKEN error.
Duncan
Duncan Brannan
If my post was helpful to you, please could you give "Kudos" and/or mark the "Accept as Solution" button(s) below. Thanks in Advance!
You are not logged in.
Ask the Community
