DWG TrueView
Active Member
lopui
Message 1 of 5 (1,241 Views)
DWG TrueView 2013 Cannot Open the Second Time
1241 Views, 4 Replies
10-18-2012 09:40 AM
before I remove my older version of TrueView, I installed TrueView 2013-32bit on an XP with all .Net 4 and it worked fine the first time I opened. The next day I open TrueView 2013 it has the following message:
Unable to run DWG TrueView. This may be due to one of the following:
1) This version of DWG Trueview was not installed properly. In this case, you may wish to reinstall DWG TrueView.
2) You do not have sufficient rights to run DWG TrueView.
Wherever I open a DWG files, it gives me the following message:
Unhandled Access Violation Reading 0x7ef61180 Exception at 77dd6d48h
The old version viewer works fine. Since I want to make sure the 2013 will work and I don't want to uninstall the old one.
Any idea? Why it worked the first time and then crashed?
pendean
Message 2 of 5 (1,235 Views)
Re: DWG TrueView 2013 Cannot Open the Second Time
10-18-2012 12:16 PM in reply to: lopui
Did you try #1, and ensure #2 is not the problem?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Member
lopui
Message 3 of 5 (1,228 Views)
10-18-2012 03:42 PM in reply to: pendean
Yes. I did uninstall and resinstall Trueview 2013 and I have Admin rights. Other thing I would like to mention is I still have the old version 2007 in the computer since I want to make 2013 is working before I uninstall it. Do you think it's a problem. Is any other way I can make sure 2013 is working before I remove the old one. thanks.
pendean
Message 4 of 5 (1,217 Views)
10-19-2012 06:01 AM in reply to: lopui
I've never done that, so I can't answer your question.
Active Member
lopui
Message 5 of 5 (1,206 Views)
10-19-2012 07:03 AM in reply to: lopui
Anyone has any solution. I want to make sure Trueview 2013 will open dwg files created by all the older versions since we have many files created long time ago with older ACAD.
You are not logged in.
Ask the Community
