DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
DWG TrueView 2013 Angle Measurement Problem
2 REPLIES 2
Donpk123
2725 Views, 2 Replies
The angle measurement tool does not produce the results I would normally expect.
For example, if I have two lines, one vertical and the other horizontal,  at 90° with a common vertex and I click I both lines with the angle measurement tool, the results show 0.0° instead of 90°.  A third line, 20° CCW from the horizontal line, shows an angle of 70°, instead of 20°
Am I doing something wrong, or is there a problem with the angle measurement tool?
   Don
2 REPLIES 2
autodeskuser234
in reply to: Donpk123
Are you using Ctrl 9?
bmnajath
in reply to: autodeskuser234
how will take angle and radius calculation  via DWG trueviwe
