• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    DWG TrueView
    Active Member
    DWG TrueView 2013 Angle Measurement Problem
    883 Views, 1 Replies
    09-01-2012 11:50 AM
    The angle measurement tool does not produce the results I would normally expect.
    For example, if I have two lines, one vertical and the other horizontal,  at 90° with a common vertex and I click I both lines with the angle measurement tool, the results show 0.0° instead of 90°.  A third line, 20° CCW from the horizontal line, shows an angle of 70°, instead of 20°
    Am I doing something wrong, or is there a problem with the angle measurement tool?
       Don
    Please use plain text.
    Member
    Re: DWG TrueView 2013 Angle Measurement Problem
    03-08-2013 01:17 AM in reply to: Donpk123
    Are you using Ctrl 9?
