• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    DWG TrueView
    Member
    Accepted Solution
    DWG TrueView 2013 64bit, installation: asp.net 4 problem
    6845 Views, 9 Replies
    06-18-2012 12:16 PM
    hi,
    i have a problem during installing dwg trueview 2013 64bit on an windows 7 64bit professional. i get always the following error wheter i have installed it or not.
    i downloaded the current available asp.net (dotNetFx40_Full_x86_x64) with all updates
    error message: you must first install microsoft .net framework version 4.0 sp1 or greater berfore installing this product
    i hope anybody could help.
    greetings
    gregor
    Please use plain text.
    Member
    Re: DWG TrueView 2013 64bit, installation: asp.net 4 problem
    06-26-2012 11:47 AM in reply to: gregor2005
    push.
    no ideas?
    Member
    06-28-2012 07:14 AM in reply to: gregor2005
    It needs SP1 for .NET Framework 4.
    This may help, it's what I use for mass deployment for my company.
    Article IDs for .NET Framework 4
    2656405
    2656351(2 updates)
    2604121 (3 updates)
    2656405
    2487367
    982671 (Actual .NET 4)
    2487367
    Just go to Microsoft and download the KB articles mentioned above. Hope that helps.
    New Member
    07-11-2012 11:57 AM in reply to: gregor2005
    Download net frame 4.5 from microsoft site. if still got problem email me i can teamview to install for u
    Francis
    mycomputer_2002@yahoo.com
    Member
    07-11-2012 04:07 PM in reply to: edgonz
    @edgonz: thanks for your hints. after install all kb's and separate all out i found it was that i have to install asp.net 4.0 full and KB2604121. now its time to deploy it on all workstations :-)
    king regards
    gregor
    New Member
    07-19-2012 07:57 AM in reply to: gregor2005
    Congrat! have problem feel free to drop email to me. Best regards ? Francis Ng
    New Member
    10-31-2012 10:33 PM in reply to: gregor2005
    so I am still having this problem today, does Autodesk even care to address it?
    Distinguished Mentor
    ampster
    11-01-2012 06:38 AM in reply to: watassek
    this forum isn't for contacting Autodesk about problems with their software.  The forum was created by Autodesk for end users to submit questions/answers, and every now and then an Autodesk employee might jump in and provide some help.
    Other than that, have you tried the suggestions listed above, stated by the OP as to have been solved?
    Valued Contributor
    11-02-2012 08:20 AM in reply to: ampster
    Agreed! There are posts regarding this issue all over the autodesk forum but they don't work! Some patch would be good. This looks like that Autodesk issued software without checking if it can actually be installed on different operating systems.
    Distinguished Contributor
    11-05-2012 06:48 AM in reply to: Barvas11
    The solution I found was apparently in the installation package of the full version of ACad 2013.  As in, by installing the autocad package, the necessary modifications were made by the software to the .NET framework; when tried again True View could then be installed without the previous .NET error.  It was very frustrating, and still is since that makes for a long-way around to a fix.
