DWG TrueView
New Member
SRG88
Message 1 of 4 (966 Views)
DWG TrueView 2012 on Citrix
966 Views, 3 Replies
07-07-2011 10:47 AM
I've successfully installed DWG TrueView 2012 (64bit) on a Citrix XenApp 5.0 - 2008 64Bit server.  It appeared to install the DWG TrueView software on the XenApp server with no problems or errors.   I then proceeded to publish the TrueView app.
The problem is... the app appears to run successfully as long as the user is a Domain Admin, or the user is part of the local Administrators group on that particular Citrix XenApp server.   If the user is a regular user, they get an error when trying to run the TrueView app where a window pops up for the user saying "Preparing to Install".  Then after several seconds it fails with the error "DWG TrueView Application has stopped working", and gives the option to Close the Program.  (As mentioned, the user does not get these errors, and the TrueView app runs fine as long as the user has some sort of Admin rights or belongs to the server’s local Admin account).
Has anyone had this experience and been able to resolve it... without having to make all the TrueView users part of the Local Admin group on the XenApp server?
New Member
Message 2 of 4 (910 Views)
Re: DWG TrueView 2012 on Citrix
07-20-2011 08:13 AM in reply to: SRG88
I'm actually dealing with this at the moment. I'm taking samples of the registry and profile data before and after to see what's being added. Are you using roaming profiles? I'll investigate and report back.
New Member
SRG88
Message 3 of 4 (907 Views)
07-20-2011 08:29 AM in reply to: SRG88
Thank you for the reply.  We are currently using roaming profiles in our environment.
New Member
Message 4 of 4 (895 Views)
07-21-2011 02:47 AM in reply to: SRG88
.. I can tell you what it isn't.... closer, getting closer.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
