I am new to this forum and also a novice at Autodesk products.
Recently, I had to reinstall a drafter machine and I installed his Autodesk products as well. Because I got into problems with getting the right products for licensing, I uninstalled everything and reinstalled all Autodesk products again, but I got into problem reinstalling DWG TrueView 2011 as it kept saying that "the program is already installed". After couple hours of research, I figured out how to remove that by deleting the reference in registry. Then I did another attempt to install the DWG TrueView back.
However, instead of installing DWG TrueView 2011, I mistakenly installed DWG Trueview 2012. I uninstall 2012 following the uninstall intructions, and reinstalled DWG TrueView 2011. Installation completed successfully, but when I started up the applicatio, it gave me the error "FATAL ERROR: Unhandled e0434f4dh Exception at fd3dcacdh. " and crashed. (screenshot below)
I did a bit of google search but didn't find any solution to this. Does anyone know about this error? Can you please help me with this? I don't want to do the uninstall and reinstall again.
Thanks in advance
