• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    DWG TrueView
    Active Member
    DWG True View install that can be used for 32-bit or 64-bit machines.
    3616 Views, 2 Replies
    10-01-2012 01:31 PM
    I would like to include the excellent DWG True View on a CD for my customers (so they don't have to download, many of them have poor connections to download about 1 gig).
    Anyways, there is a 64-bit and a 32-bit version of DWG True View.  Obviously some customer will be using 32-bit and others will be using 64-bit OSs.  Therefore, I thought I could just download the 32-bit version and put it on a CD.  Then the 32-bit version of True View 2013 would be installed on the computer - no matter if they had 32-bit or 64-bit OS and it should work.   Or so I thought.
    Seems like there is something in the install that actually prevents the user from installing the 32-bit version of DWG True View on a 64-bit computer.   Why is that?   Is there a way around this?
    The only solution that I seem to have is to point them to the website - or put both installs on one DVD.  :-(
    Also - FYI - the 32-bit version of the DWG True View 2013 installs seems very flakey!  I kept trying to download it and it "appeared" to have downloaded, but it didn't.  I kept finding files named "SetupDWGTrueView2013_32bit.exe.part" or "SetupDWGTrueView2013_32bit.exe.2.part" instead.
    Peter
    Please use plain text.
    pendean
    Re: DWG True View install that can be used for 32-bit or 64-bit machines.
    10-02-2012 04:42 AM in reply to: tenshekels
    "put both installs on one DVD"
    ... and provide clear instructions for your recipients: if they can install their own software, they can do a little reading too.
    Download DWGTRUEVIEW direct:
    http://download.autodesk.com/esd/dwgtrueview/2013/SetupDWGTrueView2013_32bit.exe
    http://download.autodesk.com/esd/dwgtrueview/2013/SetupDWGTrueView2013_64bit.exe
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Active Member
    11-12-2012 05:47 AM in reply to: pendean
    Eh, not the answer I was hoping for.
    This is the obvious other "answer" that I was trying to avoid.
    Thanks for the response though.
