Does anyone know if their is a way using Orca to modify the .msi installer file and shut off Hardware Acceleration by default during the install?
If not, is there a way to shut off Hardware Acceleration for all users by default after installation?
Solved by ukdxb012. Go to Solution.
I do not know about question #1, but for #2, you can add /nohardware at the end of the Target path.
Right click on the icon used to launch DWG TV and choose Propertities then adjust the Target path to something like
"C:\Program Files\Autodesk\DWG TrueView 2011\DWGVIEWR.exe" /nohardware
for example.
HTH
This only works if you are launching the app from the icon. When you launch directly from a drawing file, the setting is not applied. Are there other options?
Installation Help from Autodesk:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
Hi Duncan,
I don't think you understand the problem. That solution only works if you launch from the desktop shortcut. If you try to launch the application by opening a .dwg file, it does not work.
Let me give you a for instance:
I am in windows explorer, TrueView is NOT open, I double click on a .dwg file, it launches Trueview and then the error message comes up and I cannot view the file. Then I have to go to the desktop shortcut, launch Trueview from the shortcut with that /nohardware tag and then either open the .dwg file from inside Trueview or go back to windows explorer to open the file.
Hopefully that clears it up, if not I will record a video and post it.
~James
Hi James,
Try these key's in DWG Trueview 2016... 0 = off, 1 = on
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Autodesk\DWG TrueView\R14\dwgviewr-F001:409\3DGS Configuration\Certification]
"HardwareAvailable"=dword:00000000
"HardwareEnabled"=dword:00000000
There is a user-selectable option in the program!
Just right-click on the icon:
at the right-end of the status bar and select "Graphics Performance...".
Once I got in, my settings looked like what is shown in the attached file "dtv_graphics-performance_pop-up.png". By making one change, DTV is now working properly for me. The one change is shown in the attached file "dtv_graphics-performance_pop-up_intermediate-mode.png". I just changed the setting for "2D Display Settings" from "Advanced Mode" to "Intermediate Mode".
Before the change, lines on the bottom 1/3 of my DTV window were missing. See the attached file "dwg-trueview_graphics-bug1a.png". The point at which the lines would disappear would change as I scrolled up/down. If I scrolled my drawing up high enough in the DTV window, all of the lines would be shown. If I scrolled my drawing down enough in the DTV window, all of the lines would be missing.
