DWG TrueView
Active Member
patrickkey3871
Message 1 of 10 (752 Views)
DAYSTAMP
752 Views, 9 Replies
03-06-2012 11:18 AM
I am opening a drawing with DWG TureView, the drawing opens, although the DAYSTAMP does not correctly show information, all I get is the red box with diagonal lines.
The attached dwf shows the DAYSTAMP in the upper left corner of the page.
Please help.
pendean
Message 2 of 10 (748 Views)
Re: DAYSTAMP
03-06-2012 01:28 PM in reply to: patrickkey3871
What created the "daystamp"?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Member
patrickkey3871
Message 3 of 10 (746 Views)
Re: DAYSTAMP
03-06-2012 01:30 PM in reply to: pendean
AUTOCAD??? what do you mean what created it?
its the standard DAYSTAMP and its being used in 2007, 2008, 2009, 2010 autocad, and civil 3d.
Active Member
patrickkey3871
Message 4 of 10 (745 Views)
Re: DAYSTAMP
03-06-2012 01:31 PM in reply to: patrickkey3871
if I plot it out of autocad to a dwf file then all works great, but if I use DWG Trueview, or Design Review, the stamp shows as seen on the attachedment.
pendean
Message 5 of 10 (736 Views)
Re: DAYSTAMP
03-08-2012 04:47 AM in reply to: patrickkey3871
There is no DAYSTAMP command in AutoCAD: so you either used a FIELD,or PLOTSTAMP command or the old classic Express Tool RTEXT, or a third party add-on?
Active Member
patrickkey3871
Message 6 of 10 (728 Views)
Re: DAYSTAMP
03-09-2012 08:21 AM in reply to: patrickkey3871
Classic misunderstanding. The block "DAYSTAMP", old school block used to display the drawing plot time, date, file location, etc......
Its a AutoLisp routine, display correctly in all format drawings, although as shown on the attached drawing, does not show correctly in DWG Trueview.
Maybe I need to resvae the block in a newer format to be able to have the display of the stamp work correctly, I will try a few different ways.
Thanks for the help.
pendean
Message 7 of 10 (725 Views)
Re: DAYSTAMP
03-09-2012 09:40 AM in reply to: patrickkey3871
What are the object types used? That's where it's failing, and why. The object type is not supported in the viewer.
Active Member
patrickkey3871
Message 8 of 10 (723 Views)
Re: DAYSTAMP
03-09-2012 09:51 AM in reply to: patrickkey3871
My bad, RTEXT
pendean
Message 9 of 10 (721 Views)
Re: DAYSTAMP
03-09-2012 10:16 AM in reply to: patrickkey3871
LOL, Express Tools must be loaded to see their custom objects: since you cannot install ET in the viewer... no objects, just a box.
You folks should get into FIELD command in AutoCAD, or PLOTSTAMP as a minimum.
Active Member
patrickkey3871
Message 10 of 10 (719 Views)
Re: DAYSTAMP
03-09-2012 10:21 AM in reply to: pendean
Its hard enough trying to get users to remember to have plot stamp on, thus the daystamp. I will investigate the FIELD command.
THanks again.
You are not logged in.
Ask the Community
